Good point. The door latch is on the left, I just naturally installed it on that side.
what reels are you using on your trailer, @anon82972966?
Wow that fit on there better than i thought it would.
Right? I plan to add some pressure treated plywood underneath for more stability.
Get you a irontron pump up sprayer they shoot extremely far. Way better than my Tractor supply ones. Northern tool sells them
What do you use the sprayer on? Oh and where is your water hose?
You need a pump up sprayer for alot of things. My water hose from my tank to washer or hose from spigot to tank?
Spigot. I have a 100’ 3/4" hose and it’s a bear to haul around.
I have 200 feet of flexzilla light as a feather ill be hooking it to a float value soon as in comes in the mail
The flexzilla hose is great racer showed me ut and been a fan ever since. I think alot of guys on here use it too
Get the 3/4 if you can. I have the 5/8 its easier to find and they sell it at my work
My direct drive machine pulls water just fine.
I hooked up the tank today with the electric pump, works fantastic. I may try again straight front the tank to the machine when this rain lets up.
So this Flexzilla, it’s the water supply hose correct? I’m sure it’s lighter than the 3/4" commercial hose I got at Lowes. Sucker is heavy.
Read up own a few of these its good hose. Durable, strong, flexible, expands and is very light. Only down fall is its got some friction to it. If you stretch out 200 foot of it and try to reel it in on a hose reel its can cause friction on the ground and feel heavy but if you grab sections of it ad you walk back to your truck upon leaving the job you will be fine great hose.
Reviewers point out heavy mold growth, noticed any?
I seen that too on one post. I havent used it long enough to know im sure some guys on here could tell you but why worry? You’ll have strong bleach at your disposal lol
Listen to @racer. Your new and may not know him well but hes got plenty of experience with it. I think hes converted alot of guys to it. Hes also one of the best on here for 12volt pumps.
