No, but I don’t run it 8 hrs a day everyday, so it should hold up fine for me. It has a one year warranty.
Yeppers. That’s how Russ set his up with the dema valves. I love tinkering, but not really with electronics. It’s really hard to beat @SchertzServicesLLC remote. All the components separately run about $400 so I really don’t see how he’s making much profit, but it’s a solid design. Not knocking what @Steve has. He is where I was a while back. Those solenoids get super hot after being on soap for an hour or so straight.
My rotary valve is $35.
Link?
That should have read “a $220 actuator valve” I wasn’t specifically refrencing your valve, just saying generally speaking.
Any one has experience with this banjo valve? I’m using US solid , after 4monts started making some clicking noise, still works. I think about trying banjo next.https://www.spraysmarter.com/liquid-application/valves/electric-valves/3-8-full-port-banjo-mini-electric-on-off-ball-valve-lev038pl.html#/
I use the same valve @dcbrock uses. I’ve had good success with them, just changed it out half way through this season. So 1 1/2 seasons for 35.00 not bad. About 15 minutes to change out. Only uses electric when you open or close it. Stays cool as a cucumber.
Yeah…and now that I religiously flush the valve every job it’s been working perfectly.
Link to the valve?
Their description sucks.
Pretty sure it’s the one Squid, IBS, and others were talking about ba year or more ago. I’ll see if I can post a link.
And possibly the best.
Sorry if I over did it. You can understand why my wife is typically annoyed. ![]()
Please cease and desist using that meter, I have a patent pending on all soft washing assemblies.
Or pay me treefiddy to use it ;>)
I’ll get a check out to you on Monday. Not this Monday, just a Monday.
Please and thank you
Motorized Ball Valve- 1/4" Stainless Steel Ball Valve with Standard Port, 9-24V DC and 2 Wire Reverse Polarity by U.S. Solid … https://www.amazon.com/dp/B06XWYW9ZR/ref=cm_sw_r_cp_tai_FwavFb7W48DZ0
I emailed BANJO about that valve to see if the SH would be an issue but they never contacted me back. I got the impression that unless you’re looking to order a large quantity or become a dealer, they aren’t interested in your questions.
