Please tell me how the ball valve and 4 to 5% works.
Restrict the volume of waterâŚdraws close to same amount of SH = Stronger solution being applied.
Not rocket science.
Guys lets just be alittle more kind to the new guys⌠I get it, he should have done more research but were all here to learn and help. Lets all be cool. Dont let this place become a toxic dump of know it alls and noobies. No one benefits from that.
by the way iâm a new guy. I donât have a rig or a trailer yet. But i am obsessed with learning as much as possible and being the best at doing it when that time comes. I dont even know how to check my hours read maybe innocentbystander will come by and tell me im a noob too lol and he would be right lol. All im saying is lets all be cool please.
by the way i am just realizing this topic was from a long time ago and probably didnt need to be brought up BUT with that all being said. Everything i said still applies lol
have a good day guys.
Think I might have learned this today. Lol. He was rude to me on one of my posts but I guess because he knows allot he can be ? I just dont see how thatâs very professional. To bash or make rude comments to a small timer, or up and comer. Idk maybe Iâm the jerk? Lol
Take it with a grain of salt. If he was rude about something I can be 1000% sure he was being honest about it.
Weâre supposed to be grown men here and Iâve seen so much butt hurt from military veterans, grown men, and professionals AND been butt hurt a handful of times. I went off on @Nashvillewash about something a couple weeks ago and Iâm still embarrassed about it.
It wasnât even any of my business.
If weâre being honest with you about something itâs to save you money, time, or headache, or make you money. Weâre not getting paid to be here, but most are here to be as helpful as humanly possible.
The most beautiful thing about the internet is if you read something you donât like, you can find the same info somewhere else in a way you will like it and you donât have to give the other one a second thought.
Iâll bet $100 today that if you stick around for 6 months youâll use something IBS has said and it will make your life easier or put money in your pocket. Bookmark this. If you donât, Iâll send you $100.
Duly noted sir !
Question : I bought a 4gpm/4200psi PW with a Honda GX390. I also bought the Jrod nozzles for Soft Washing roofs and houses. I use 10.5% SH. Can you please tell me your thoughts on how to make a 5gl bucket solution? The Ownerâs Manual says that for every 10 gallons of water it uses it draws 1 gallon of solution. So 10:1 , but will that be strong enough to kill all the black algae stains on asphalt tire shingles?
Mitch M. ; :5
No. Needs to be about 3-4 times that strong. Use the search bubble above for âroof cleaningâ
NoâŚ
Thanks
Pepper learn your percentages for what will clean siding, roofs, brick and so on. Very important. The mix you described would be about 1% which is good enough for most vinyl siding but thats about it. Also if you are using the built in chemical injector on that dewalt machine stock up on some good injectors from pressuretek because that one is gonna fail on you pretty quick. As mentioned earlier, one of the downfalls of softwashing with a pressure washer is you canât really make hot enough mixes for jobs that need it. The xjet is an option that can help that. Or you may just have to use a pump sprayer.
Couldnât you just use regular soap tips with the xjet to do a roof rather than restrict the water flow with the ball valve? I am assuming you are using the ball valve to take away some of the pressure that the xjet uses (because it soaps with high pressure). Also, since the xjet is rated for the GPM of your machine wouldnât the restriction of GPM from the ball valve make the desired chemical ratio inaccurate?
I use a150 psi air compressor with a 1/2" air pump and can shoot 3 stories at 90 psi and up to 17 gpm. I can run pure bleach through the pump if needed with no damage.
First, how you going to use any tips with xjet? Second, you arent going to restrict with a valve and get any desired results
modify itâŚhelps reduce misting.
Take a variable soap tip and turn it into a fixed soap tip?
