Soft wash questions
If you are going to use it that way ds injectors are much cheaper. Just put it in the same place as the modified xjet. The xjet is just a ds injector with an old style admiral fan tip screw in basically. I’ve helped make a couple thousand of them back in the day.
Who’d a thunk it?
Hmmm, I didn’t know that. Good to know and I’ll look in to that. Thanks for the advice.
Local company has been washing that way for 20 years. They carry a one gallon jug of mix with one hand and spray with the other.
Seems like so much work lol
they only do residential. It works for them. Superior runs about 6 trucks and 12 or 15 guys year round.
When I need an x jet they’d usually how I do it. Set a couple pre mixed gallons around the house and you’re ready to go. I hate carrying around 5 gal buckets.
I have heard of people using multiple injectors on their pressure washers to increase the SH%, has anyone tried it?
just get an x-jet…
Using multiple injectors back to back does not work, only the one closest to the pump will draw. As far as how to increase your mix strength, you can always get a smaller injector, you can get a stronger SH concentrate, I believe they Even make injectors with an interchangeable orifice to control strength.
