I can build some roof pump systems if I need too. But the proportion valves are expensive. Unless you just use standard ball valves and find a sweet spot and mark it on the valve.
Ok cancel my order. I never DS anything except straight 12.5. If I dilute its always too weak doesn’t work. Not sure if it’s my setup or my SH. Thanks anyway. I’m still excited to see your work. I’m sure it’ll be top notch.
This is a soap switch that just switches you from SH to rinse.
So if you are downstreaming 12.5 that’s fine. You use your own injector. All this does is makes it where you don’t have to walk back to the truck to switch from chemical to rinse.
Gotcha. I seen your first post a while back and made me one. Couldn’t wait. My first try didn’t go that well. I think you helped me with the wiring the second time around. Third try was a charm. It’s been working great. I use it daily. Thanks
I made one using the same electric ball valve, added a horn to the exterior of the housing. So when I switch from ds to rinse or visa versa a get a beep I can hear all the way around the house to know that the remote worked
I found a box that makes a chirping noise. They normally install them on heavy equipment and the sound chirps while the outriggers are moving. But if I could find a low decibel horn that just honks briefly I would use that.
I have a secret up my sleeve that will make them last a long long time. Also adding parts to take the voltage pull off the remote system making it last longer too.
