Ok. I do like the injectors, but I’ve broke the blue plastic off of a half dozen until I thought to rotate them down lol.
I know it sounds silly… and it felt a little silly the first couple times… but man… after that I won’t leave home without 5 in the bucket just in case.
I keep my hoses locked together on the reels with them. If I only need the 1st 75’ I camlock it off and lock it right to the filter and away I go. Like legos.
And on a side note, send me pics of that stove in action if you ever get another cold snap
I’m freaking dying to use that thing. Moved out of the shop yesterday so my home shop and trailer is packed out with black and yellow tubs. When I get everything situated I’m gonna fire it up for a few beers by a lawn chair.
Thick coat of paint on the faucet… the aluminum hose end was not going on. Tried it yesterday… wanna know what did go on without much trouble at all?
5/8 is plenty big enough, any spigot ive hooked up to fills the tank faster than i can drain it with 3k 8gpm
You must have some good flow around you! When I was running my 200 gallon tank last year I was waiting at 1/3 the houses!
im in southern oregon so maybe lol i always thought city water pressure was pretty standard but i guess maybe not
I’m batting 50-50 lately on water. Had a little house Monday, showed up with 200 gal and tank was dry before I finished rinsing one side. Flow was so bad broke out the 4gpm machine and still had to wait on water over an hour on the job.
My goal is to always roll up to each house with 275 and leave with 275! I installed the Hudson valve today and here at my house I have slow flow. Still filled the tank quick.
One thing we have in Western Oregon 8s water!
Baffle balls?
Don’t run em. If the tank if full it doesn’t slosh.
How many boxes did it take to fill the tote?
Did not fill it.
Ordered 30 only to see how they looked, and cool
It will take 1440 to fill, they seller did the math.
But i am going to buy corrugated pipe with holes and then fill the rest with these.
The 65gl bleach leg tank 600.
And they are SH >20% “excelkent”
https://www.calpaclab.com/ldpe-chemical-compatibility-chart/
I’m thinking about running these in my 55 gallon vertical tanks. Maybe do 100 or so balls in each, which I think should take up about half the tank. I read that they float, so they’re always where they need to be to cut down on sloshing.
Did you get the Wiffle brand balls?
Thats where i bought mine.
Hank, the owner, is cool
I also stumbled on these, works out a little cheaper (and I like the color )
Those are 11" circumference… thus 3.50" diameter.
Smaller than WIFFLE BALLS.
But no idea if those are SH resistant
