Did you mean massaging?
Not a chance, I’m happily married Messaging as in private message!
I have the rubber grippies that go over the wrench teeth but I did forget to use it lol. Not at all marked up badly. Still looks great and performs!
But yes, send me the 6:1 once you get it machined and I’ll borrow it and test it out.
13/16" 12 point socket or a flare nut wrench
Is there an actual 6:1 injector coming? Based on what GPM machine?
10gpm 6:1 theoretical in the works after PW Gadgets releases their high draw for 4-8 gpm
Do you know the timeline to have a 6:1 for 10 gpm ready to send out? Theoretically with 6:1 it will give enough strength on a 10 to downstream on stucco and brick with that type of strength injector, apply degreasers to a large area, and acid wash large areas too.
All I’m willing to say right now is it’s in the works. I hope you understand, I just want to under promise and over deliver not the other way around.
My injector showed up in the mail today, can’t wait to give it a shot. The build quality looks to be extremely high. Also ordering was straightforward.
Thanks for that, let me know if you have an issue with the ball/seal.
I had no idea what that was and then I googled it and saw it’s a line wrench then the flare nut part made sense lol
Long day
Well, I stuck the check valve part in the vice and just twisted it off with my hands. But I do have flare wrenches in the trays so I’m probably still good
I could probably afford a set of those Snap On wrenches if I got a second mortgage. Instead I run these:
I don’t shop on the tool truck I pick up my tools on Ebay
Oh here we go with the fancy pliers again!
When I die they’re yours
I hope they’re never mine then.
