Yes, plus you dont have to hold the trigger the whole time. Do you have a ball valve on your hose?
Sparkles a ball valve is added weight. You’re doing good with out it. Lots of stress on the unloader. Use tools for what they were designed for and your equipment and your insurance agent will like you for it ball valves are designed to be open or closed. They do not shut off when dropped…
Pretty much but most of the time I just hook my jrod into my gun and use the low pressure 15 or 25 degree tip.
Well, the xjet allows me to adjust the stream on the run. When I find a stubborn spot I dial down the fan and eliminate the persistent area or colony of whatever tiny creatures survived the surface cleaner. Then I adjust the fan to whatever pattern best suits the depth of sand and dirt that were left behind by the Hammerhead.
Just so you are aware, you can also remove stubborn spots with a ball valve. You just have to hold it down near the concrete, and it will clean them.
Here’s a couple of guys rinsing with ball valve:
I would like this post but I don’t wana get yelled at again. Good videos to encourage the use of the ball valve.
I didn’t yell at you, in fact, i said lets shake hands like adults and move on. Up to you.
I’m making a joke fella
Somebody seriously needs a hug. You up for it IBS?
LOOK GRASSHOLES, quit taking yourselves so fargin’ seious already, eh?
Oh, BTW thanks for the vids! AND, a ball valve is definitely on my imporant but not vital list to be sure. I’m working on a $500 job that required me to buy a $259 ladder, and that’s how things will probably go for me until I accumulate the tools I need.
I better quit poking the teddy bear. Peace love and cheerwine
huh? I don’t get it
The Buddha is said to have quipped, “not every lesson is for everybody. Take what works in your own life and abandon the rest”.
SO, if you aren’t the grasshole who gets his knickers in a twist, that post must have been for someboody else.
What’s a grass hole?
Is it a hole where you put your lawn clippings?
Because where I’m from we don’t put the clippings in a hole. We put them in a pile. A compost pile. Like normal people.
I think if you’re digging a hole just so you can be putting your grass in a hole… that’s a huge waste of effort.
Unless you’re taking rectal marijuana in which case I y misinterpreted your post … um… “just be yourself man!”
Who even wears underwear to work? It’s just a conspiracy by Big Fabric to make you buy more clothes
I’m pretty sure big fabric owns all the tuna boats as well
That’s the funiiest shite ever, Dude! I can’t see the frikkin’ keyboard cause my eyes are atering
No twists here, can promise ya that. Takes a lot more than this stuff to get me to tag all my friends and make a dramatic exit.
Ok fine… that statement isn’t true.
“Friends” shouldn’t be plural.
Fact.
Uey, wher you been all wekekend? (Still tryin’ to get the water out of my eyes from laughing so hard at Buzz’s post)
