Stainless ball though
Ceramic is much better
Actually ignore my question, I do not think the psi is rated high enough for pressure washers. I just thought I found something new and could be cool like squid…
Don’t know anything about that one, but don’t be so hard on yourself. Lol
Which part went out? Mine went out and I never opened it to see if a rebuild would suffice. Had a regular on hand and been using it.
Another one today. The ball gets stuck in the oring. You can free it once or twice but that’s about it
Maybe a titanium ball would be best.
Ball is fine. O rings are just too big
Do the orings start out as too big? Or is it wear. Viton cords can be purchased and made plus they glue together with a krazy glue type product.
After about a week of the ball slamming into them they either soften or wallow out, causing the ball to stick halfway inside them and not release
OK so this happened. I called dultmeier and they’re sending a replacement immediately and another spare for me. I told him about the ball sticking, because it happened once with this and he said he was aware and guys were just shooting a quick blast of air in the barb to free it and it only takes once and no problems after that.
Scavenged the top from the old one. Found an o-ring that’s a little fatter than the old but seats perfectly and it’s viton. Hope that helps.
Most excellent
Thats what I was thinking, i hope you can update this and it works out.
tried ordering from them but too confusing…
I dont know about you guys…
But mine last me years and they are GP
Dadgumit !
I just punched in “downstream injector” in the search bar and order the first stainless steel one I saw. I was in a rush when I did it. I’ll give it a try, looks like you can adjust it by twisting the black part.
