1/2 in
Clean plumbing behind the proportioner and schertz box. Also made filters for the SH tanks from PVC Waiting on some parts to come in for the tanks to connect them. Will update then ![]()
Looking good. Where’d you get those filters though. Don’t like, holes too big. They won’t keep out much. Get the ones from PWS, have lots of tiny slits in them.
Was thinking the same thing. The slotted ones from pwp or pws have held up great this year and were well worth the price.
After watching this video and seeing how buildup can occur in SH tanks, I’ll be ordering those filters lol. Thanks ![]()
You can make your own filter with slotted well point tube from Home Depot. 4 ft tube. You can make a bunch from one tube. Buy the 1.25 pvc end. Glue it. Then the 90 1.25 to .5. Screw your 1/2 pick up tube into it. A lot cheaper than buying premade. I get time is money so this option isn’t for everyone. Good stuff to have laying around the shop
https://www.homedepot.com/p/Water-Source-1-1-4-in-x-48-in-Plastic-Well-Point-WSWP125-4-PL/308717695
Thanks Tim, didn’t realize they had the slotted at Home Depot.
I already have it on the way, I went with the 3/4 tube
You have the link for 3/4”? Can’t find it on Home Depot site. Thanks!
Not Home Depot, pwp.
Here’s the Link
Yeah, I have those already. I thought you were talking about the one you can make yourself as Tim was describing. Thanks though.
Just the one I linked. I’d also be interested in the 3/4.
I’m assuming your blue hose is soft wash or roof wash. If so get rid of that swivel and put a poly swivel and stem in.
Does that even exist ? Just searched for it and no luck. I have the E1526-17-18
I will send you a picture when I get home
@DJPWS actually I know kleen rite had them they are titan 8700 pvc swivels somewhere around 40.00
Do they work on Hannay reel ?
Found the Swivel
Edit.
If that swivel fits, i could order some pvc and make my own stem
Cold water only though.
I have no way of running hot water through it unless I fill a fiver with hot water from the washer which I can’t see why it would be necessary.
Lukewarm water to mix chemicals in then 12v should be fine through it.
Or try sun bright supply. They are in Maryland. They have a website but it’s horrible way easier just to call them
