Hi guys. I hope everyone is doing well.
Just checking in to see if anyone can help me with a couple of wiring questions I have:
I’m running a wire from a battery to the starter on my GX690. I have to run it about 8’. I’m planning on using 4 gauge wire. Is that large enough for that long of a run?
I’m also setting up an electric hose reel for the first time. I’m planning on using 4 gauge for that as well. My plan is to run my set up this way: battery to bus bar, then run wires from bus bar to reel, starter, fuse block, then to run wires from the fuse block to my 12v roof pump and chem remote. Does that sound like the right way to do it?
Thank you, in advance, for your help!
