Which Hannay Reel?
I’m ready to order a Hannay Reel for a new trailer build (starting shortly) and have been reviewing the Hannay site. It looks like I need either the E1530-17-18 or the SNC-18E reel but I’m not sure which one.
My specs are:
  • 1/2" hose x 50’ + 3/8" x 200’-250’ hose (2-wire?)
  • 1/2" manifold through the reel
  • SS in the fluid path
  • electric rewind (12V)
  • 4000 psi rating
This will be for downstreaming and maybe a 2nd reel for roof wash
For those using Hannay reels, am I looking at the correct products? Which reel do I need?
Direct links to the reels:
This is what I use. It’s not electric but they suck anyway
They can’t suck, it says right on the tag “you can’t buy a better reel.” What more proof do you need?
I really like mine. There’s really not a lot to go wrong with them. We keep a solenoid and switch on hand just in case but so far we haven’t needed them. This is how we have them set up
Electric sucks. Hannay is the best reel made
My shoulder disagrees with you.
You change your trailer up? Looks different than what I remember.
I’m on like my third change. A friend of mine is part owner of a ornamental steel fabrication company and we built a rack and reel stands last Friday might. I moved things around to make room to switch out the hydrotek for the magnum. I really like the hydrotek. It’s a gray machine but is hard going from 8gpm on the water dragon down to 5,5. This way my hot and cold will be 8gpm. All nozzles can now be the same. University medical center has the same machine and it’s built like a tank. We’ll see how it does. The good thing is they’re local and should I have an issue they’re here to take care of it. They’re putting my hydrotek in their rental program
How does the Hannay hold up to the elements? Im in the middle of a an open trailer build and was curious if its going to rust.
10 years in the elements and no rust so far
And you’re just using the 1520-17-18 right? Not the SS one?
Mine is holding up great
What do ya’ll use for your supply line to spigot. To hold ,say 200’ of 5/8 hose?
I use 3/4 flexzilla with a hannay 1" manifold reel
Same model # as @Innocentbystander ? Btw nice set up man. @Kps0410. I know you have electric wind. But I’m getting manual. Is that 200’ of 3/4 flexzilla in you’re pic above ?
I only have 100feet on the reel but could probably get another 200 feet on it. Very seldom do I need more. my supply reel is manual
Thank you sir
Thanks my friend. I was wondering about that ,I’m also running thick wall 5/8 hot,cold hose. I’ll just call them and get the proper one. Thanks again @dperez
Does it have a hand crank if the electric fails ?
No it has a bolt that can be used to turn the reel with a wrench or socket. I keep a dewalt 1/2" drive cordless impact on the truck in case of an emergency. but I also keep a spare solenoid on starter button on hand. I’ve never had a problem though
