Hey guys I’m down streaming 12.5sh and elemonator. But
still. Am I using too much elemonator? I try to guestimate 1 oz per gallon of bleach… I Also has to squeegee the windows afterwards
still. Am I using too much elemonator? I try to guestimate 1 oz per gallon of bleach… I Also has to squeegee the windows afterwardsLooks like it’s from the weep holes or you let your mix dry. Did you reapply and rinse? Or just try rinsing it off? You don’t need to guess how much surfactant you’re using, get a measuring cup. I use one of my daughter’s old sippy cups.
You just missed a spot rinse till you think your done then do it again
Either you got water in a weep hole or under the vynal from washing to close to the house shooting up
Or
Its a old red mud stain. Try resoaping it and rinse it with a soft mist. If it still leaks out wipe it with a rag until it stops. If resoaping will not remove it use aluminium brightener.
I’m at 8 ounces of elemanator per 65 gallons and that is to sudsy sometimes. But, you just need to rinse again to clear the weeping
Lucky you i usaully have to resoap and rinse my injector back off if it dried on the house. Seems like if it dried water just wont get it all off.
That’s mind boggling. I wonder if it has anything to do with hard vs soft water or any other variables within the water itself. I’m at 1.3oz per gallon and I still desire more. Rinses easily.
I run into the same problem with shampoo and well water. I feel like it’s never rinsed out. I’m used to that dirty hard MS river water.
Same here i usaully add 2 or 3 more ounces then recommended. I like a good sud makes me feel like im getting it really clean lol.
Same issue here, our TDS is around 220. Soap takes a while to rinse.
Probably is guessing how much mix he has. Alot of people dont have markers on thier tanks like us to know.
I thought you were “glug, glug”. I guess I had better start measuring because I’m currently using “glug”…lol
I think it dried on there. It didn’t affect have the same on the shaded side. Thanks for triggering that realization.
Was that side of the house exposed to sun while you were working? What do the other sides look like?
Its just dried up soap. Spray ox acid on it and mist it off. Happens all the time with the weeping holes. Simple fix.
It’s not an exact science lol
Measure and record my friend. That way if there is a problem you can find the culprit quick. We have little ratio cups it honestly might take 15 seconds longer to pour in and dump it. I found ever since we started doing that we started going through it much slower. Some of my guys might have a “glug glug” others a “glug glug glug” approach haha.
Hey when you mist on acid. What brand do you buy and do I just down steam the entire outside with the acid after the bleach and before pure h20 rinse
Don’t mix bleach an acid…ever. No need to use any Oxalic acid on this at all. Just try to rinse it off and if that doesn’t work soap it then rinse.
