What do you guys think about this video.
He’s using a downstream injector like an x-jet…
Instead of putting the injector at the machine,
He puts it just before the gun.
He says he can get 3% mix doing that way…Just jump to 1:29
I don’t trust guys that wear white sunglasses
Hey, he had matching watch band, he’s cool.
Sheesh, if I needed to do that, would break out the Ryobi and been done with the pre-treat while he was setting up. But interesting, though I’d never do that. Of course I never use a Xjet either.
It’s an “up stream injector” he says cause it’s “up stream”…
That would be down stream buddy. Just like your down stream injector is down stream…lol
Seems like quite a hassle for just the gasket around the garage door. A pump up takes 20 seconds. It is good thinking tho. I have an xjet but have never used it. I love my M5 twist now. Thanks @Racer
I think it was @DantheWindowMan the made his own xjet out of an injector. It might’ve been something else tho. I can’t remember exactly.
The 20 seconds includes walking to truck to get pump up I hope, lol. I pump up those gaskets, front stoops if needed and any other tiny tidbits of excessive algae. Easy peasy
It does. I was also picturing a 3 stall garage in my head or else I would’ve said 7 seconds…lol
You tube should only be used for learning how to do brakes on a 30 year old 4 wheeler and listening to John Pine albums. Never use it to learn how to pressure wash
I’ve watched quite a few of his videos. I actually like them.
I think it’s that he’s so down to earth and isn’t acting like he’s the best guy always making $300+/hr like many of the YouTube guys come across. I like that.
Even this vid I was like “hey, that’s kinda cool”.
A guy I went to high school with is a country rock singer/songwriter. He wrote a song about John Prine after he passed. It’s not too bad.
That guy is absolutely clueless
That’s awesome
Yup, but I put mine after the gun as part of the lance and removed the guts.
I made one, as well. With a 3 way valve mounted under it so it works as a 2 step gun.
