Thought I’d share a video I took today of us washing a tanker with the two-step gun for those that are curious. Using Supersonic and Dynaclean & Bright from Hydro-Chem. We can do the whole truck and trailer in about 30 minutes like this. In the video it looks like we just turned the aluminum white but it’s not as bad as it looks. Still shines once it gets rinsed and dries.
Employee should have soaped from bottom to top and he didn’t need to go back over the whole thing with acid but what can you do!
I’ve looked into truck Washing as we are close to a major highway transition and a turnpike changeover. If seems like most companies want this done for free. Chemicals seem expensive but they work well. I just cant figure a way to make it profitable.
Also it’s not like it’s going to harm it unless it dries. If you take your truck through a car wash you’re getting close to the same thing sprayed on it.
Here you go. Slight correction: I said the hose is “vacuum-packed” when I really meant to just say “vacuum”. Also, I’m not affiliated with PowerWashStore in any way. I know Hydro-Chem makes a two-step gun as well but it’s significantly more expensive.
Just a brass coupler. Holding up fine! And yes, as mentioned in the video, I was told it soaps at about 1500 psi. I’m going to experiment with it and see if I can get it any higher.
UH-OH. what ya gonna do now @dperez?? @pressureguy is now up streaming and DS at high pressure, basically at the same time without going through the pump ,with environmentally safe soaps n acids …
