First time practicing on composite at parents house. Used pump up sprayer to apply it
Looks a lot better. How strong did you go?
Looks good. In the future you could prob just downstream your mix or if its really bad x jet if you dont have a 12v. Itâll save you some time
2-3% @Racer
I havenât even bought equipment yet so thatâs why I used the pump sprayer. Even washed it down with a hose lol. But still 100x better than how it would look normally with my dad using a pw. Notice all the scratches
How many GPM is your pressure washer?
I tried the longer hose on my xjet pail. All it did was tangle up and tick me off. I have about 12â on it now. I dont really use it much though. Only on stuff that needs a stronger mix than DS is capable of and here and there on a post treat
I shortened my xjet hose to about 2.5 feet. When I need to hit a spot with a strong mix of bleach or OneRestore or whatever, I just stick the drop tube in the gallon container and carry it around with me.
I donât bother with the poly ball valve; just pull the drop tube out of the jug and suck some air through it.
This has worked surprisingly well for how little I use the xjet.
What chemical did you use for the composite decking? I see 1-2% but didnât catch the chemical.
Thanks
Just SH with a little roof snot - just a weak roof mix
