I have a cheap one before buffer and a nice 2" filtet after buffer. I never checked them because I didn’t think much would come from spigot. At the end of the season I checked them both, the one before the buffer was loaded with crap. Probably from my guy dragging the supply hose around. Surprisingly the one after tge buffer had some very small debri in it. Things that could have caused some problems in my pump.
There are many ways that debris can find it’s way into your water supply, that’s why I have filters. I’m not needing 10 micron because I’m not filtering drinking water or running sensitive medical equipment. I’m protecting my pumps from debris that enters the water supply. Also my 2" Banjo strainer is 120 mesh which is 125 micron.
Mesh to Micron chart - Just for reference anything under 40 microns not visible to human eye. A particle of pollen is 60 microns
Put a filter BEFORE your buffer tank. No problems
No spigot debris. No tank debris.
I like your setup! I’m anticipating starting a softwash business as a parttime gig while I’m working, and unfortunately I drive a car so I’ve been thinking about purchasing an older Tacoma for a setup like yours. What parts did you use to set this up? I’d love to mimic the setup, thanks for sharing.
