I completely agree. A lot of products need more real life testing. They probably had some employee doing test runs on a newly poured pad of concrete behind the shop.
@Harold I dont know anything about those but can you clock the bars? Also are you blowing surface off before and after pre treating
I do when it’s apparent that it needs to be done but otherwise no. I haven’t had this issue with the other WW cleaners not once.
I’m not sure what clocking the bar means but I read the instructions and they didn’t mention anything special. Plug and plat get to work
Glad it worked out for you man. Could of been way worse @Harold .
Not nagging. But everyone make sure there fire extinguishers are up to par …
Oops, should of put that in your other topic. My bad
One on the trailer and one in the truck at all times
Great advice/ i overlooked it for quite some time.
Why won’t pressure and water be equallly split in a Tee?
Also, why would a parker Tee be your choice?
The lol part means it’s a joke. It’s the most expensive tee I could think of. They’re about $80 in 3/8 size.
You were correct about the mondo performing better then the big guy. However the big guy worked flawlessly through roughly 40k sqft. I had several issues with the mondo. I will revisit it in the future. Possibly with some of the modifications that were suggested to increase bar clearance. Hopefully WW does it but it seems that most people have been happy with them.
How have things been with your mini mundo since this thread?
