so you recommend, with what I have. reducing the length of hose?
So do you recommend the 1/2 hose on 12v soft wash systems @Racer
Idk what the issue was. I checked all the connections. turned back on and I finished roof and house without loss of pressure. im baffled
Sounds like your pump isn’t priming properly. Do you have aMother pump you can test?
I use same pump with 200 ft and have no problems up on two story roofs spraying
Is it primed?
1/2” works fine on 12v
Yes, for sure
I did some research on priming pumps. my understanding is that you turn on and hold open nozzle until no more air comes out.
I will start using my ball valve correctly now. To maintain the water in the line, and make priming easier. Im definitely more aware of what it is now. I think that may have been the issue.
Great, hope it works out!
Those everflos are self priming I know, it’s weird that yours isnt
Self priming doesn’t always mean they prime. Sometimes they just need a little liquid in the pump to get them going. You can see the mix pulling a few feet into the pickup hose but that’s it. Once you force a little water to get inside it takes off. I use to just take a hose and force water into the end of the wand to get it going. I now have a 3 way that connects to the bottom of my buffer tank that I can turn in order to get water to help prime. I also use that to flush.
I do the same, works well.
Gotcha maybe I’m just lucky with my pumps then! I’ve never had a problem with them priming
