I’ve been using the blue Kuri Tec 5/8” for 2 years for my roof pump, which also doubles as an sh transfer pump. No issues whatsoever, just thick and heavy.
I use the yellow now. It’s the same one that came with my bandit. I’ve had no problems with it, other than it’s not blue. Its 3 years old and I figure Its due to be replaced.
Call Lori down at PWP. she’ll get you the right Kuri tec and price is about the same. On my new one I got 250’ for $185. Plus they’ll crimp SS ends on it for you. You don’t really want the one you show. You want the one that has a shiny finish to it instead of the mat finish. Mine was red, but they make it in blue too
1/2" RED KURI TEC HOSE PER FT -15 TO 150 DEG F 0.813
OD 300 PSI MAX WORKING PRESSURE AT 70 DEG F 180 PSI
MAX WORKING PRESSURE AT 122 DEG F CHEMICAL
COMPATIBILITY RATING OF ‘A’ FOR SODIUM
HYPOCHLORITE (CHLORINE), SODIUM HYDROXIDE
(CAUSTIC SODA), OXALIC AC
You want the 1156, not the 1176 Will stay nicer looking longer and slides better
