Sodium Percarbonate recipes
Yes it’s water based
15 min is what I usually go based off for dwell time, keeping it wet
The customer was the one who requested to spot sand and set nails. He asked me to check over his work prior to staining
balusters looked pretty good so he won’t have to touch those
[/quote]
up to 15 minutes in my mind is cleaning, 30-45 minutes is stripping an old coating off.
The scuff test is the only way to know when to start rinsing, and even then you might need to reapply in sections/areas.
I’m 4-6.00 per sq ft and 3-5.00 per linear ft on railings with spindles. It depends on what is on the deck now, what they want to go back with, condition of the current coating, how big a PITA the railings are etc. I’m in DFW and I really don’t do a lot of decks, homes here are primarily slabs with a cement or stone patios.
