Got to teat these today.
They are awesome
Davis Shooter Tip Holders right?
Yes they are
Both 8/4 do DS .
Comparing them to a 0040 tip
The 8 shoots about 5ft further, and the 4 about 15 ft further.
So 10ft difference between the 8 and the 4
I have both as well. Kyle is a good dude. He’s making basically M5DS tips now. I can’t wait to try them out.
Met him yesterday.
Cool dude.
Likes Lori as well…
Can you post your results with the m5ds tip of his once you try it out? This is cheaper than the m5ds I just bought.
Your running an 8 gpm unit and using his 8 shooter tip correct? You get 5 more feet of reach with a tighter stream?
Yes.
My back up is a 4gpm
The 4 tip givrs me about 15ft more than a 0040
I always buy for both machines just in case.
thank you
I run an 8 and 5.5. I need to test his tips. I use the guy Blackmon shooter tip but have his 8 and 4 shooter tips as well.
Never heard if that person.
Only reason i bought these was because the guy is local and liked how they looked.
Also the tip holder are light and good looking
ordered one, look forward to getting it!!
Me too!
How are you guys switching between soaping and rinsing with these tips? We run 4K 4 GPM machines and use 0040 for high soap and 0010 for high rinse.
I use the same nozzle to soap as I do to rinse.
I shut off my injector. Same tips for soap and rinse
Change tips .
Or shut down feed
What tip are you changing to to shut off the soap? Do they have a separate soap shooter and a rinse shooter?
I understand using only one tip and shutting of the injector when rinsing. I guess the disadvantage would have to be running back to the truck or using a remote controller.
Sorry if I am misunderstanding how these shooters are designed to work…
how long you been in business?
I don’t rinse above 100psi so that I don’t knock off oxidation or cause other problems. Using a high pressure tip to stop my injector would be a bad idea. I kind of like the trip back to the truck because I like to see that the equipment is still running properly and there’s not a massive leak somewhere. Plus I’m putting on a little bit of a gut lately; a little more excercise doesn’t hurt
Been in business around 10 years. We run a truck with two 4 gpm machines. Mostly house washes and residential concrete. We downstream and have used the 4 way J rod from pressure tek since the beginning to soap and rinse high and low.
