Im trying to limit the amount of hoses I have and wondering if I can use my 150 for 200 ft of pressure washing hose when I want to use my roof pump.
I know most guys are using 1/2" braided or Flexzilla for their roof pumps.
My pump is Amarinemade 65PSI and 5GPM and has a 1/2" barbed end on the outlet. I would have to run a small piece of 1/2 " hose with a quick connect fitting to go down to my 3/8 pressure washing hose. Would that work?
Pressure hose isnt meant for that strong of chemical… itll eat right through it, you need a separate hose. kuritech, poly, or flexzilla are really the only longterm option
Using a 3/8 hose will cause more restriction over the distance needed. 1/2 is the standard minimum for roof soft wash units to allow efficient application of the chemicals at a higher %.
The hose restricts the flow through friction. The connect will restrict it some yes, but not as much as 200ft of hose. Also you need a hose made for stronger chemicals or you’ll be buying two hoses pretty quickly.
