I have one that i will be using next month for the first time in 3 or 4 years. After that it’s your for $200
If he doesn’t want it I’ll take it.
I’ll take if its still working after then, lol.
It should be . This one is set up like a 28” maxima . On casters with the same handle as the classic
I need one with the fixed rear wheels because of the aforementioned reasons
I didn’t want you to have it anyway you SOB. just kidding.
I’m actually getting rid of a bunch of stuff in a few months. I don’t want to drag it to the new shop just to store it there.
2 8.5@3500 cold water units with high hours
1 complete hot water 8gpm trailer unit with a air pump system
Several tanks
And possibly a 55hp Diesel power unit set up for two pumps.
Racer, question for ya: I’m running a 24" Lil big guy - 2 nozzles (the 4 nozzle bar left tracks as well) on my 8, 3500and getting horrible efficiency, can you see the tracks? I even went super slow. Any ideas?
Are you running correct nozzles? Have yo played any with adjusting height? that’s a really nasty drive. Did you pre-treat really well? Get it wet and keep wet a little while. Make sure you’re not letting dry too much before you rinse. post treat the heck out of it. and sometimes you have to wash both ways or just go over twice. The bottom pic though, good post treat will fix, though it could be a little cleaner to start with.
How much hose you running? Have you checked your pressure at the nozzle at the end of however much hose you’re running? That would be the first thing I did assuming I was running correct nozzles.
Adjust the height? Can I asjust the height on my pro eagle? It’s basically a classic from what I understand
Sorry for the long delay. I don’t remember the nozzle size off the top my head - 25045 i believe. No i haven’t done height adjustments. I don’t typically treat at all, my 4gpm 4k psi classic used to get it without a problem. When I do treat, it does make quite a difference and it is easier with the 8. The after pics I did go 90* the other way and it did clean them quite good.
Typically 200’ hose, have not checked my hose pressure recently.
Thanks
Your the man @Racer , ordering one today with of course a second pair of tips to make it a 4.
