Yes thanks but my wand is connected to the entire thing and my surface cleaner has its own handle
Yes, remove the handle and replace it with a male qc piece. Then you can use your gun as the handle
Ok thanks so much
@Jake_Lambert
My hose connecter can unscrew correct?
Can’t *
Also where is your ball valve and do you use a filter?
Welcome. It’s not nearly as awkward as it sounds like it would be, actually I find it helps me keep the SC from floating too much because the grip on my right side is now forcing it down. I’m only running about 2500 psi on the surface cleaner, but 7gpm and a 19" SC
I don’t know, send a pic of it. I have no idea what equipment you’re running lol. I don’t have/need a ball valve- my gun stops the flow and connects to all my accessories
OHHHHH I get it
@Jake_Lambert
I haven’t gotten it yet all I ordered was a generic 4200 psi 4gpm and a whisper wash Untra 16
I have a 1.5" banjo filter on the outlet side of my bypass tank and a plastic screen filter on my downstream tube
@Jake_Lambert
Honestly I have no idea what you mean
That’s a good match at that gpm. You can absolutely unscrew the handle on that SC, it’s the same one I have but a little smaller. Best SC you can buy. I kept my SC handle as a backup to my backup gun lol
Awesome so should I purchase a new wand as well
No worries. At 4gpm you probably won’t be running a bypass tank, but if you stay in the business and invest in your company you’ll change that all pretty quick. I’m not throwing shade at all, just saying you’ll outgrow 4gpm and then you’ll be adding all kinds of tanks and bypasses and downstream injectors. And eventually buy a Shertzbox lol
It’s a little uncanny how similar our setup and equipment choices are. It’s basically a trailer version of what I did! How do you keep your jrod so clean? Mines showing rust after a month…
I appreciate it so what kind of connector should I get I’m still a little confused so sorry I’m educated in this as much as you I’m on 15
What’s a j rod
Any suggestions on making my sc last as long as possible?
You mean you don’t polish your jrod at the end of each day before you place it in it’s own case with a memory foam cut out?
