I just bought a used GX390 with a blown pump. I don’t care about the pump, just the engine. Thing is, I can’t get the pump off! I’ve changed over lots of these, but this one seems like it’s seized on the shaft.
Bolts are out, the pump moves left and right, but it just won’t pull off.
Look at the side of ur pump… where it goes on the shaft. Look for s hole, or a slit and a small Allen head screw. Take that out …,some have them some don’t
As @Patriotspwashing was saying some pumps have a tiny set screw that will not let you slide the pump off. I’d check for that first before going the pry bar route.
I just have to say this. I know you’re from down under and y’all do everything bass ackwards but around here we use The Freedom Measurement System. I only tell you that because we have no clue what you mean by millimeters and centimeters and whatnot. INCHES! WE NEED INCHES AND FRACTIONS OF INCHES!
