Are these wfp connectors?
I don’t know how to answer that as there is no such thing as WFP connectors. Only borrowed from elsewhere. They are plastic tube fittings used in laboratories, food and beverage, manufacturing plants etc. What size do they use for WFP?
Mine are 10 mm. I just bought my first wfp and would like something like i saw on your picture where it Makes a Y, so i can feed 2 poles off one pump… I’ll look it Up!
10mm is almost equal to 3/8" I wonder if that’s the OD measurement on it?
Those are terrible but they should suit your needs
Why so?
Nylon bodies, Nitrile o-rings most likely
So what are the tubing fittings that you use made out of? And where can we get them?
I’m using tube fittings for SH. He’s looking for fittings to use with a WFP. I’d go with Acetal or Polypropylene with EPDM rings. They are cheap in those materials. For SH they are pricey. I get mine from Parker. What do you need exactly? I may already have them if not they will take up to 6 weeks to make them. Kynar raw base material is in short supply so they turned them all into made to order.
Not in immediate need of anything. Mostly just curious.
Kynar FKM
I cleaned a little piece of debris out of mine and now it’s doing the same thing again lol. Ever time I think the kinks are worked out Murphy’s law targets over
Then please come put front shocks on my 2500. It will suck way more than my fords
How are you getting debris in there? The filters @dperez sells are working great on each of mine.
Oh they’re easy peasy. I took both of mine off when I rebuilt the front end of my truck and they come off and go back on in a minute or two. Are yours rusted badly or something?
I don’t use filters. Just one more thing to have to worry with. A piece of the kynar barb chipped off. Filter wouldn’t have caught that. I guess it damaged the ball or seat. I’m going to try one out the two new ones and see what happens.
It’s slightly leaking past the ball now?
Where did that come from? Are you talking about a metering tip?
No. It’s blowing like it was last time. There was a little shiver of the kynar metering tip inside, but I cleaned it out.
