As you can see this thing is a lop of ■■■■. I am going to have to use some huge carriage bolts that will most likely not be long enough or be a bit to long. You made a wise investment.
Sure. Large fender washers, old lawn mower beat flat with holes drilled or something substantial to hold on the bottom. Some folks use stainless and there isn’t anything wrong with that. I use cheap grade 5 bolts and cut them off when I need them gone. Faster than wrenches.
I bet you could step on those ears and bend them. No way to get your hand under there to tighten bolts on pump or engine once it is bolted to floor. Need to be about 4 times thicker and about 4 inches high.
My landa guy just had 6 Stainless steel skids made to celebrate his 20th year in business. $800 as compared to $400 for steel. I think he was showing off but he sold all six in a couple of weeks
Nice, I was wondering how I was going to drain oil. That seems like an ideal machine. I am probably going to use a local dealer instead of the internet for my pressure washers. They will custom make them and know how to repair them. I suggest @jzbreeland do the same. Unless he is even a tiny bit more mechanically inclined then me.
Before you mount your PW remove the oil plug and put a nipple in there. Then attach a length of hose to it. After you mount the pw - cut the hose to length and put a nipple\ plug on it. Now it is easy to change your oil…
Heck no. I’ve got more than six of the steel ones though I have steel frame from Xterior from about 1999 that has been added to and cut down a lot over the years. Lot of machines and pumps have been bolted to it.
My pump will probably break because of my own stupidity before I need to change the oil. I do however think it will be a decent investment and worth it once the time does come.
