So just got my trailer line x and paint hopefully start putting it together soon…
Looks sharp! Any reason you didn’t go up the door with liner?
Looks great.
It does look really nice. I’m also wondering about why the doors didn’t get coated.
Also, what made you choose an enclosed trailer vs an open trailer?
I just told the guy I needed the floor done and up the walls a little… I ask about the doors he said most of the other trailer he has sprayed he never did the doors… maybe he didn’t feel like preping the doors…I will keep a eye on them…
Looks really good Justin
Thanks going to try and build it kinda like your setup… but I won’t have hot water or two machines… think the hardest point is going to be the plumping with it come to the 12v setup
Looks great, are you going to paint the walls white?
Looks great. Keep us updated on the build progress. What did the line x run ya?
Ok so finally was able to start putting stuff together it’s not all finished yet…still lots still to do…
Got a good start on it…looking good
Super clean dude. I really like it so far.
Even if he doesn’t want your suggestions, I’d like to know what your suggestions would be just for knowledge’s sake.
Yeah man let me know that’s why I posted the pics
Pressure reels always go on bottom. Torque will cause the whole tower to twist, especially on Titan reels. They are flimsy at best. Needs to be attached to the wall as well. Much easier to use mounted at the back of the trailer where you have the option of pulling either direction. Now you can’t place anything on the floor between reels and door, have to go inside the trailer every time you switch from soap to rinse.
Yeah , I have the reels mounted on the back wall u might not be able to see the bracket on the pic… reason my I mounted the reels on the side door is because most of the time I can pull right up to a house and run the hoses right from the side to the house… when i was using my truck, reel was mounted in the back, so it became a pain when it was time to reel the hose up… (I would have to pull the hose straight back then go reel again pull the house back then reel again ) do that with 200 feet of hose pain… now is should be a straight shot from the reel to the house… also keeps me dry when it’s time to reel in the hose if it starts to rain…lol
@Innocentbystander no need to go inside trailer to switch from soap to rinse just use the j rod or if I am using the mx5 x jet thing I am putting a value on the ds line on the back of the trailer right where the house wash mix is going to be
