I only offer soft washing so using a high pressure tip to stop soap isn’t an option. My jarrod rods only use 3 tips
I know a guy named Jarrod actually. Could he be the same dude?
If the house has oxidation I will use the same soap tip to soap and wash with… that’s why I am putting a little value on my downstream line … I don’t have a lot of pressure on my machine either only 2500 psi with 200 feet of hose 8 foot jumper line I might be at 2000 to 2100 at the tip)
Jarrod gumbolt made the jrod that pressuretek carries. A lot of us have made our own long before that
I know one thing I am glad I did go with the line x I can wash the floor no problem
Dude, that looks fantastic.
Question, how will you store the sc And ladders?
Looks great Justin. I do agree with IBS though, I’d think about switching reels - put your water high and pw hose low. Know that you’d have to bend over to switch injector bypass on-off though but may be worth it. Just keep an eye on it if you decide to wait.
You’ve still got some nice room at front to put some shelves and storage. Have seen guys use those cross braces between walls for ladder storage and even surface cleaners.
Thanks I might switch it, don’t know yet Reason why I put it high is because I didn’t want to keep bending over to reel the hose up… and the pressure hose would be the one I reel the most …
Not really, if you’re using your pressure hose, you’ve got your water hose out. The pressure hose weighs a lot more itself, plus you have to crank harder on it than you do the water hose…Maybe just drop it down to the middle, that would help some.
But try it like you have and see how it works for you.
Yeah I think I will change it up… hopefully ace hardware will let me return that poly water hose line…lol
If you’ve already got hooked up, try it like it is a few times. Just see how it does and keep an eye on it.
