My first two jobs. Thoughts and observations. Pics included
Well then. Today was the first day as a somewhat professional pressure washer. I have been researching pretty heavily for some time now and amassing the things I thought i would need for success. Here is a blow by blow of what happened.
I have two friends who happen to be next door neighbors so I offered my services at a discount for before/after photos as well as experience. One wanted their metal roof cleaned. The other wanted their concrete driveway cleaned. I decided to start with the roof as it was going to be a S___T show. It did not disappoint.
I load up my little 5.5ft bed f-150 and try my best to not look like a 99$ guy.
It was covered in pine needles and a lot of black, gross stuff. I think thats the technical term :rofl:
Ok, so everything is blown and free of debris. Time to start washing. the house was around 1500sq ft. It was in the high 40s. I didnt use my 12v setup because im an idiot i guess. I went the xjet ORIGINAL route and oh what a pain in the butt. wowzers. I ended up blowing through 21 gallons of bleach on this bad boy hitting with a mix of approx 2.88% wide open with the xjet. I coat the roof a few times letting it dwell and good news. some stuff is changing color. Its still slimier then ever though. I am working from a ladder because id like to not die…at least on my first day…
Heres what im looking at as I am starting…
Half the gutters on this guys house are absolutely full. The other half are not even attached. The pitch of this roof made water/chemical just launch right past the gutter line and all over me/driveway. I am disgusting like 3.4 seconds into this and it doesnt get any better.
I hit the stuff several times with the mix. A lot has cleaned up with rinsing but theres a lot thats not budging at all. I have to get close to it and hit it with pressure and that seems like a no no. so heres a question for you guys. Do i let that sit, and will rain/the elements deal with that over time? I know on shingles you do, but i was unsure with these. I decided to rinse as much as i can and clean it up manually as best i can without shooting water up into vents and where the metal overlaps. I lost 2 countem’ 2 rinsing tips because im a dummy who cant make sure to doublecheck they are seated correctly. luckily they werent pointed at windows but now i need to re order some as those ones i had flew probably up to the moon.
From beginning of cleaning to finish is like 5 hours. This roof is not perfectly done. I feel like i might need to get up and hit it from above to clean off the rest of the stuff. I did as best as i could for the day and feel like its Joe 0 Roof 1. I feel like there was more than just algae there and it was a much bigger job than anticipated. In a perfect world i would throw that xjet right in the trash and go 12v and hit everything with a hotter mix. Or not do metal roofs. The jury is still out on that one. Heres what it looks like after im done. These before and after pictures suck so i apologize in advance.
After this i head next door to my buddies house who would like a cleaned driveway. This is my first time using a surface cleaner and wowee…this is kind of fun. Much less curveballs being thrown at me with this. I pre treat with 2.88% using that xjet. Have I mentioned i hate this thing? yikes.
This driveway has definitely seen better days but good news is its older than 2 years and i dont have to worry about any cream being left. hahah. I am taking it real easy as theres some exposed aggregate.
I do the outer edge first and then do horizontal lines back and forth just like @Racer showed in his youtube video. Forward on line, backwards on line. It cleans up quite well in my opinion. My opinion isnt worth much but its all i have to give.
I post treat with 2.88% and knock on the door to grab a beer. I feel like ive earned it. I spent 7 hours total on 2 jobs and then packed everything up and headed home.
I feel ashamed to admit that i did a less than stellar job on that roof. I feel like im going to need to take another crack at it in the future. It looks a million times better but i dont think it would be as good as any of your guys’s. I also feel pretty beat up. Backs on fire and shoulders are a little tired. Im sure that will go away with more practice but all in all i feel like this was quite a learning experience and i am glad that i got out there and got some experience. Also glad that these are my friends not customers and are only paying for the materials i used.
Fun story…get a nap lol.
I encourage the spirit, no insight to offer on that metal roof though…
That roof seemed like it had a lot of stuff on it but I have no frame of reference. The top right corner still looks a bit rough because the ground over there was super uneven and I couldn’t get closer to it without the ladder being super unsafe so I called it.
Aside from that I feel it looks ok but I’m ready for you all to roast me :joy:
Im assuming i need to use a hotter mix? Should all that black in my pictures just melt away on its own or does it require a bit of water pressure?
2% and a brush. sometimes, don’t need to brush super hard, just takes some contact. Nice write up and not bad. Probably 2 of the toughest jobs you’ll ever have. Driveway was in bad shape, will look better when dry. Good effort. Kudos
I think it came out great for your first play. To answer your question, you never want to spray SH on a metal roof or metal anything and let it sit there like you would a shingle or tile roof etc. SH accelerates rust and corrosion, you always want to rinse afterwards, make it a habit. That roof would have no drama taking a 1000psi for the caked on stuff with a bit of common sense and thought about the overlaps. As the saying goes - you can’t softwash everything.
Thanks for the reply. I probably should have phrased my question better with letting it sit. I definitely rinsed and rinsed and rinsed some more. Will rain and such wash that crud away since it’s dead now eventually or is it stuck up there until I get up there with a brush?
I guess the plan of attack on that roof or metal roofs in general that are gross would be to have the mix and a brush with a telescopic pole from the ground or if you get on roof start at bottom of roof and work backwards with a brush so you’re always walking on dry metal.
You can’t soft wash everything. That’s the first time I’ve heard that phrase after all the reading I I’ve done! Learning that my first time doing a roof is awesome. I will definitely be charging accordingly next time.
Killed it for the first two jobs.
I don’t walk many roofs but that’s one I would.
My experience is after a good rinse with a fan tip it’s not really slippery at all, even wet. Most roofs like that I downstream, let soak once or twice and then hit with the fan tip out around 8 inches out or so. If it’s super dirty maybe x jet and then fan but I always need a little pressure on a roof like that.
I went back to that roof because I don’t enjoy failure. I brought with me a 2 gallon sprayer and a telescoping brush. I almost died like 5 times but I’m learning :joy:.
Did a few sections at a time with sprayer and about 3 percent, then I would brush and it all came up pretty easy. Definitely will bring a brush with me from now on. Hit a few areas with just the SH to see if it melted it and I could rinse…no joy.
My mantra while walking this roof scrubbing before heading to another house wash was “see? I regrouped, came back and made it right. I ain’t no 99$ guy!”
![IMG_20220428_143801473_HDR|375x500](upload://8zSm0tsvY7BpgBd0GerM39sihlg.jpeg
All those easy shingle roofs around there that look like they need washing, and you get that one… :rofl:
Way to keep at it! Be sure to put some cards around to all those neighbors, they might think you just clean metal…and don’t realize they need it done.
Ive found roofs & I are unfriendly at the moment haha. I definitely need to get more familiar up on them
Wow man, talk about trial by fire. A nasty metal roof as your first job?? Looks really good now.
Get a long extendable pole to put that brush on. Don’t walk those metal roofs. You typically don’t need to brush them hard. Looks good now. Nice followup.
It extends like 8ft but I definitely need a longer brush
Get the 8’-24’ extension, it comes in handy sometimes.
One I have - Also good for knocking down those high wasp nests, which you probably don’t have up there, lol.
Not a lot of protestants round these parts :wink:
Looks nice, but pricy! I have the one from Home Depot and it’s plenty strong even brushing at full length. Yes it bends a bit fully extended, but has never kinked or broke on me.
https://www.homedepot.com/p/Mr-Longarm-Pro-Lok-23-ft-Adjustable-3-Section-Extension-Pole-2324/100177392
Didn’t say it wasn’t. I use to have one of those, it’s just that sometimes I needed longer. Nickski, not every conversation has to be an argument. Just giving alternatives, which you like to do often.
Argument? What are you talking about? I said that one looks nice and provided another, low cost option to choose from.
