My Beginner 5x10 Trailer Build
I started my power washing business in the fall of 2020 after COVID forced me to move forward with starting my own business. I hope no one take offense to my timing, I know the past year has pushed many new companies into the market and it has changed things. PWR has been an invaluable asset in learning and I am deeply grateful for the active and knowledgeable members here. I am grateful every day to be running my own company, for better or worse. I am no expert but I wanted to share my build for those who, like myself, are finding themselves starting up with limited help.
My wife and I are leaving Florida next month to thru-hike the Appalachian Trail for 6months & 2100mi from Georgia to Maine. This is terrible timing for starting my business but we have put it off for several years and honestly, there will never be a perfect time for such a trip. My goal over the past few months has been to learn and grow my business so that when we return I will be better prepared to hit the ground running!
I consider my build to be small but efficient!
  • 4x4 pressure washer
  • Gen III Softwash Pump
  • 2x 35gal water and SH tanks
  • DHRA pressure reel
  • liberty hose reel
  • little giant ladder (+ wingspan)
  • Stealth Proportioner
  • 100ft flexzilla hose (don’t waste $ on construction hose like I did)
Surface cleaner, guns, gas cans, leaf blower, etc. ride in the truck bed for now but I would recommend a ladder rack and tool box if you can afford them starting out so you can skip the 30min of getting everything together in the morning!
Since pictures were taken I have skid mounted my washer to the trailer and taken it off the wheels for better water flow. I would definitely recommend skipping this step and if you are doing a trailer build, assume the washer just like everything else will permanently stay on the trailer.
Feel free to ask any questions!
I really like your build. It looks really efficient and well thought out. It looks like you came up with a pretty simple solution for mounting your hose reels. Could you let me know what you used and how well it’s holding up so far?
I get a kick out of the guys on Facebook that have a trailer this size and feel like they just have to have a 275 gallon water tank.
Thanks for sharing.
@tcmitchvol I simply used 2x6s as cross beams and 4x4s for supports. I used the trailer side rail to bolt the 2x6s to and then set them on the 4x4s. I painted all the wood and my trailer is kept in the garage so it has stayed dry and hasn’t sustained water damage over 5 months of use. I used thick bolts and 2” wide washers and backing plates.
The wood has really held up better than I thought, I think with proper tlc it can at least get you through a season which was my goal.
The 35gal tanks are definitely small, but work well with a 4gpm pressure washer and 7gpm softwash pump. Minimal weight carried and minimal water wasted!
Thanks @Paul1. That should work just fine for what I have in mind.
I’ve run a 35 gallon tank with a 5.5 PW in the city and never had any problems. For me it’s more about having a place for the bypass to go rather than a drop in flow. Haven’t gotten my soft wash system where I like it yet, but I may go 65 gallons there. I did a nasty house over the summer with a 25 gallon tank and had to refill it a couple times with the 5.5 softwash pump. It was portable and a pain pushing it around when full.
That’s cleaner than 80% of the builds I’ve seen on here by “experienced” folks. Well done.
@Pau1 if it hadn’t been for that 2020 catalyst, I’d still be 9-5pm shaved n suited up(or on zoom🙄), plotting instead of playing. Nice job with the build!!
Did you build the softwash platform? Looks like Aluminum or Steel.
Good luck with your business! And the hike!
Florida fuzz probably has its focus on other things, but it might be worth knowing how to convert that SH tank to a DOT-legal setup if you choose to.
