Mixing Help
So maybe I am not explaining correctly. I am going to drop my soap line in 100% non-mixed soap. So when I put my proportioner on my line it will pull at 100 parts water to 1 part soap. I am not premixing the soap and then go thru the injector
Does that change your mind?
I wouldn’t even try to reformulate. Just go with what your set up for and do a test. Doesn’t work, throw more Nerta at it,works ,then stay there or throw less Nerta to save $$
There’s just under 4 litres in a gallon…did I help? School was a while ago I currently speak in gallons unless I’m buying bags of milk…
So I asked on the fleet washing pages and got that we are both saying the same exact thing. That 15 gallons to 1 gallon is the same as 15 liters to 1 liter. The injector is pulling in parts. At least thats the 100% consensus so far
But, you are still downstreaming correct? Like with your pressure washer and not direct application like with a 12v or air diaphragm pump?
Yes. But if you just use your current proportioner you always use and it works then you don’t have to do a million tests to get the soap choked down to a piggy bank friendly environment
This. Do this. I’m so lost and thought I was helping but I think I’m making it worse. Hotshot nailed it.
So wrong. Just so wrong.
:joy:
I think we were speaking two different languages. @Hotshot nailed it. When I use my proportioner I am getting the final ratio at the end of my lance (what goes on to the piece I am cleaning).
I forget you fleet guys do weird things instead of downstreaming. My apologies. I respectfully bow out of this one and to any future readers just know that it’s a Monday and I’m actually much dumber than I let on. Good day.
Forget the whole liters to gallons thing. We’re not building pianos here. We’re squirting bugs and grease of painted crap that rolls down the highway @ 65mph. If you have good results @ 25:1 or higher and it’s cost effective in price and shipping and rinses off fast and you like it, winner, winner chicken dinner.
I DS all day long bubby,your on the right page man. We’re not much different than ya’ll think. We just use alot of different chems and either 2 step DS or 1 step US with a certain temp and have a different target to squirt at .
Is what George is calling a proportioner at the end of his gun the same as a two step gun? I’m trying to imagine what the heck he means by that but all I’m coming up with is maybe an xjet or something similar? I have never owned one of those so I’m not really sure how they work.
they go in your 1/4" soap line (click the square to see picture)
Ah, I gotcha. I’m a simpleton. Nevermind me la di da di da
You can do the same with ya’lls SH ,put that in you DS tube to get your ratio on spot. So you don’t have to premix your chemicals, we 2 step with either a dual lance or ya’lls lance with a black tip. But we have a 3 way valve to DS acid first the switch the 3 way to DS soap over top the acid to do a non brush truck wash. The porporationers just meter the amount of chemical coming in. The KISS factor. So I know my bla,bla, colored tip is set to 25:1 etc,etc. And my guys can’t turn the dial up a use a tremendous amount of soap to get the truck clean in record time because they have a hot date,or completely ruin a 200k truck paint job from Alkaline soap shock.
@hotshot are you burning alive over there on the east side? It’s hot here today. I took today off because I’m not feeling well and I’m so glad I did. I would’ve probably puked and passed out by this time. I had to give up the cigarettes last week because it was really starting to mess with me when working.
Hotter than a popcorn fart over here @DisplacedTexan , we’ve been off since Sunday night. But got to go in tonight and tomorrow night from 6pm till 2am. Then off till Friday,Work every weekend. Trucking schedules dictate our lives unfortunately.
Hope you feel better man.
Thanks man I appreciate it. I’m sure it’s just withdrawals from not smoking and I’ll get over it. I wish I could wash houses at night. Stay hydrated and don’t forget breaks. It’s still in the 90’s with the heat index at 10pm around here
