UAMCC?
Actually, FBOP. Once enough of my “so called” friends were busted, it was just a matter of adjourning a grand jury. Slam dunk! Original sentence 375 months. WHEW!
Bahahahahahah
Ouch man… Could have been worse they got the conspiracy stuff and Rico act putting people away for lifetimes…
Yep, avoided RICO, and some changes in the sentencing guidelines helped a lot
Went out on a HA lead this morning at 6:30 and found this
Will ANYTHING get this stuff clean? I have had my heart broken several times I’ve come up against it. Will heat? Is there a process that will cllean this. I have applied SH before AND after surface cleaning with a 4k 4gmp PW. Does anyone have any advice? @Innocentbystander, what do YOU do when you come upon this stuff with pebbles in the aggregate? How about it @Racer, is there a formula that will clean this crap? @squidskc, Brodie, you (or anyone else) have a solution, or should I just run like h%ll.
SO, these are the after photos:
Looks good!
very nice grasshopper
Thank you sensai
Oh yea…, that’s what we were talking about… 60 detours ago… Good job
Looks great! So how did you do it in the end?
Eliminated a hose and added a professional surface cleaner (Hammerhead). No solution, just down and dirty, hit everything from both directions (side to side, up/down) Finished up using XJet to polish off. 3 hours
If you didn’t use solution then what was the xjet for?
I don’t use a wand anymore. I use the xjet to spray clean the the surface after the surface cleaner has stripped the dirt. Is there a technique that will allow me to eliminate that step?
What do you mean when you say ‘spray clean’? Just rinsing the dirt off? Most people just use a ball valve choked down to rinse.
Now post treating, could be done with X-Jet, if needed.
Open ball valve
Open ball valve
Why> more water volume?
Yes, plus you dont have to hold the trigger the whole time. Do you have a ball valve on your hose?
Sparkles a ball valve is added weight. You’re doing good with out it. Lots of stress on the unloader. Use tools for what they were designed for and your equipment and your insurance agent will like you for it ball valves are designed to be open or closed. They do not shut off when dropped…
