That’s were @Innocentbystander get all his magic built, I gotta brother in Camp Lejeune , So I’m gonna hit 2 birdies.
Wilmington or Rocky Mount. Might be 50/50
In addition to giving bad advice, you are a liar. That’s a bad character trait.
I just ordered the remote from @SchertzServicesLLC and my methods may change after. My original plan was to buy a remote controlled motorized high pressure 3/8” ball valve and have a remote bypass as I really wanted all of my rinse flow. Once I changed to a 5-8gpm injector nozzle the difference was not as noticeable and since it was half the price decided to do the remote you have. I also like the idea of rinsing it out with water each time which the bypass doesn’t offer. Literally just had the idea it putting a ball valve before the injector to remove it for flat work and since that would work instead of turning the machine off and on to do it it doesn’t sound to bad anymore. Without the remote no way would I consider removing the bypass but this got me thinking…
Nope.
A liar? Confused maybe. Tell me again why you don’t use one? Friction loss was it?
Not going to explain. No telling what you might change it to. You made a bald face lie, and will probably claim you didn’t understand or something. I’m done with this thread until you give stupid advice or lie again. I’d be glad to see you leave though.
Whatever man. I see you give people a hard time way more than help them. Lots of other good people here to talk to don’t need your “help”
Lol.
Waiter, Check please…
Isn’t that what you meant?
That is correct. But please tell me where I said I don’t use a bypass injector because it decreases flow.
What’s the difference between losing flow and friction loss?
How is that relevant to your lie?
What are you talking about? What lie? You said you don’t use a bypass because there’s too much friction loss. We were talking about the 90° turns being a problem. All I said was that you don’t use a bypass because of a loss of flow. Isn’t all of that the same?
Please show me where I said that.
I already did. I took a snap shot and underlined it above.
And if I’m wrong just tell me the right answer instead of your elusive around the bush comments.
I don’t use them because they are an added expense that offers no advantage, they take up space, ds’ing water adds to the rinsing flow and you can’t do that with the bypass, it is more to mess up with multiple crews. You will find no where that I said “I don’t use an injector because it decreases flow”. To say that I did, and you have twice now, makes you a liar
No where in that snap shot and underlined does it say “I don’t use a bypass because it decreases flow”.
