I have a 4,000 PSI 3.5 GPM pressure washer. I just bought a 20 inch surface cleaner. When I went to wash a driveway I had streaks in the rows I did. Some claim it is “overlapping” where the disc is washing twice in the middle. I did not pre-treat or Post-treat. The nozzles are 25020 stock. How can I get rid of these streaks!?!
I know there are other topics on this, but the more I read the more confused I get on it…
The Surface Cleaner I use: https://www.northerntool.com/shop/tools/product_200659585_200659585
the Pressure Washer I use: https://www.northerntool.com/shop/tools/product_200594833_200594833
It’s the link in original post if you want to see it. 20 inch disk, the nozzles say 25020. I’m pretty sure they aren’t clogged the machine had only been used one before this job. Do you pre-treat with SH? or what mix do you use?
The link you put up is for a 8gpm unit I was assuming that was the wrong link. Just follow racers video. Definitely either buy correct surface cleaner or bigger machine. Is that a oil spot or organic stain
Gpm is king. Not pressure. General rule of thumb, you want 1gpm for every 4” of surface cleaner size. Your 3.5 or whatever needs a 12”-16” surface cleaner. Those little red/orange ones at Home Depot would work better for yours. The only thing actually clean on that driveway is the streaks.
Only Grade A though. That cheaper stuff’s got boomer pee in it and that stuff’s loaded with too many prescription drugs and supplements to be any good.
