First mix batching of 20 gallons, 6 gallons of 12.5 sh and the rest h20
I’m pretty sure I know what you did wrong. But tells about how you did it first
Haha is it that obvious I’m a rookie. Much respect to you guys. I’m trying to get hands on and troubleshooting experience under my belt.
Used a 12v pump with 200 kurtec hose and a softwash wand and tip spray. 26 gallon tank filled with 6 gallons of 12.5 sh and 14 gallons of water for 20 gallons total. Didn’t use it all of course
It was my mixing?
Do you have a photo of it was before?
What made you mix this ratio? What were you hoping to achieve percentage strength wise?
3% was I close?
I tun mine 50/50
Aren’t you nervous about having to fix and repair that now?
I clean stucco with around 3%, 50/50 is my go to mix as well on every roof (metal roofs a little less). Easier to mix as well any container/tank you have half sh half water and spray. No measuring.
It’s not damaged, it’s just not clean.
People don’t use high pressure when cleaning roofs. You have 3 hours read time and have created a bunch of posts. Spend some time doing some research here.
It’s my roof, an older guest house that never gets used.
Hopefully I get better at it and i can clear it up and make it look better the second time.
Some do or at least I have seen some videos of a guy in a roof with a surface cleaner
Oh, I though it was damaged
Not that bad then
Those guys are estupido. No good my Spanish brother.
It was close, you have to just add an “s” because it’s plural and if you are a pro also an accent. “estúpidos”
tambiĂ©n me gustan las faldas cortas en los dĂas ventistas
