EBC rates for concrete
I have plenty of degreaser on hand. Any household items you knoe of with high ph? Id hate to walk out in the morning to a mess.
Purple power, grease lighting, etc,etc will do
Ok going out to put alittle purple power on the area and rinse it out. Thanks!
@Hotshot
I know y’all think it’s funny, but awesome works man. Laugh if you want, but it works better than ANYTHING I’ve tried on grease and oil. The red stuff @ tcc doesn’t compare, and they want $7 a gallon for it. I get it from dollar tree, and have a connection that gets it for 50 cents a quart, I get 2-3 cases at a time and put it in 5gal buckets. Trust me guys, try it for yourself, soak one of those big yellow kitty CATs with it in a pump sprayer and I promise you will agree. Instantly turns to brown goo as it runs off. Was behind it and your finger will squeak on the valve covers. It’s also the best tire cleaner ever, spray it on those 24.5s and they will look like the day they were mounted. Sounds funny I know, but I’ve tried the red stuff from 3 shops, one even said “be careful that stuffs hot!” Nothin… it doesn’t hurt polished tanks and melts diesel residue instantly. Try it. It’s only a dollar :rofl::rofl:
New helper needed immediately. Former associate @Grizz blew himself up mixing chemicals in the back of his pickup. May he rest in peace.
Lil bit of this, lil bit of that, a splash of POOF!!
:rofl::rofl::rofl:
I was out on back deck a little while ago and thought I saw a shooting star but now I realize it was his Ford going over the horizon. :joy: Notice he hasn’t posted anything since he said he was going out to add some Purple Power to flush out the acid, lol.
Red neck chemistry :flushed:
It worked i guess my truck wasnt melted when i woke up this morning.
I know it works bubby ,but the money/ dilution rate stinks, I can’t even down stream it straight ,I’ve tried. I haven’t used the degreaser from TC yet,but I’m telling you from personal experience that hydrochem hcs 400 is pretty dang good, stop by and I’ll give ya a gallon. Friends don’t let Friends carry dollar tree awesome on there rigs @ShinedUP . :joy:
Sorry @Racer,this was for @ShinedUP. My fat sausages hit the wrong button
Careful with that hf. All it takes is a cigarette pack size amount on your skin, at least of the concentrated stuff, and you’re dead in 24 hrs or less. Can’t wash off the harmful part off skin, gotta put the neutralizing cream on immediately.
I carry that stuff for gutter brightening and light red clay stains on vinyl. Works great for that. Doesn’t eat the paint off gutters like gutter butter can.
What kind of wizardry gets it to work on that link but not anything else?
I’m convinced that you guys play with too many chemicals. @Grizz has blown himself to smithereens, @dcbrock is huffing Oxalic fumes, @ShinedUP has gotten a contact high and is squeaking his fingers on everything in sight, @Hotshot has ingested so many chemicals that his goatee can lift more weight than I can.
This place is a madhouse.
Has anyone tried f9 double eagle? I like it. it’s a little pricey but does a good job
Im not sure how much HF is actually in it. I have got some on my hand before and it foamed up alittle only slightly burned so probably not that much. We use this stuff for red mud removal.
I know years ago when my dad owned a PWing business. He was able to get the really concentrated stuff and downstreamed it. One of his workers had the tip resting on thier boot and pulled the trigger. It cut through his boot and cut into his foot and got HF all in the wound. The almost had to remove some toes…
:joy::joy::joy:!!!
Awesome or the HCS 400 ?
LA’s Totally Awesome. Works great on gutters. This was after having been washed with a typical house wash mix.
I’m not knocking Awesome to much @BigJake ,it just isn’t enough for the truck washing world. 64 Oz for $3 is a little pricey when you start thinking about it. Just because it’s watered down pretty good. You said yourself that it won’t harm gutters, HCS will strip the paint off gutters, mixed at 10% to a poly sprayer .So @ $4.95 a gallon for HCS 400 and you can dilute the crap outta it. I’m getting 8 to 10 gallons of a good all around degreaser with just 1 gallon or a lil less of concentrate HCS 400.
