If I want to draw a hotter mix without an Xjet could I just install a DS injector right at the gun and use my usual soft wash tips…
I was told the closer to the gun the injector is the hotter the mix.
Hey Bill, did you end up giving this a try? I just modified a GP high draw to be installed after the gun and before the wand. Ball and spring removed. Hope being that I won’t need an xjet and could do stucco and stone aggregate. I love my jrod and would like to keep using it. Here’s pics:
That’s what I am thinking. I watched a few xjet mod videos and I couldn’t understand why anyone would spend the money on an xjet just to reduce it down to just an injector.
I’d rather spend $15 on a GP high draw. Regardless, I will update my findings and bucket tests.
What about when you rinse? I find it much easier to disconnect it when rinsing instead of using the valve on the hose. You planning on putting a valve on your suction hose?
QC on the gun with no Lance and QC on the x-jet = less work carrying around the bucket while rinsing and you can use the gun for downstreaming. All my lances have QC’s on them and I don’t use them unless it’s necessary. Just makes things easier imo
