I got a call for a large house yesterday, she wants the usual done such as concrete and soffits. However her chimney is loaded with algae and what looks like soot…
I’m not really asking about what to use, my issue is the painted deck directly below. I can have someone hose it down thoroughly as I’m x-jetting but could use some advice from someone that has encountered this situation.
Yes on the painted wood. Just fyi doing chimneys like that is at least a $75 upsale. Going to take you awhile probably. If it’s a stained deck better have someone standing there rinsing. You’re probably going to need to hit that chimney 3-4 times with about a 5-10 min interval with a strong mix - think 4% or so. But that one not super bad so may not be too terrible.
Add in some ebc( $133 5 gallons) and you only need a few ounces. Im doing 2 chimneys like this Thursday. Most of them clean up pretty good with just strong bleach but its not a immediate result might take you 30mins reapplying and waiting. Definitely have the wife hosing down that deck.
It’s likely you will not need degreaser. Chimneys are mostly organic. The smoke comes out and goes up, not down as in the picture. It’s probably organic.
That’s what I thought too, but I did a house three months ago with similar crud on it and my xjet at 2-3% didn’t phase it. Definitely some sort of combustion byproduct.
Thanks for the suggestions, I’ll look into the Red Raider if this lady accepts my bid.
On certain brick it will take a hotter mix. I’m no masonry expert but I’ve run into some porous red/white brick that takes 6%+. When I pull up and see it I’m not thrilled to realize I have to hit the entire house with such a hot mix because of the watering that’s necessary. It takes a lot longer. One of the few downsides to quoting without visiting.
Especially the white brick, but the results are amazing.
I can’t dedicate more than about five minutes on something like that. Too much to get done and a foam cannon or Xjet on each truck would be to much to keep up with. With employees, keep it simple
