Yes. I use 8.5 but my machine gives out a bit more than 4gpm
Thank you! Appreciate the help!
Call me crazy, but Iām not all that worried about gpm when Iām 40 tipping a deck. I wanāt to make sure the pressure is correct. We have been using a pressure gauge and adjusting the unloader to get to where we want to be. However, I like the idea of using a larger nozzle and living the unloader alone.
I understand where youāre coming from
How to I get it back to 0 ?
I thought it was done,broke ,trash .
Ya man set the unloader, lock the nuts down ,and throw that nob in the trash
No workie. Took the filler cap completely off still @700 psi.
Its junk, These gauges are more finicky than a Galaxy tweaked and peaked CB radio wrapped in foam.
Also, messing w/ your unloader keeps your engine from running at peak RPMās.
Correct. Thereās variables though, like hose length, rpmās, etc. so w/ delicate surfaces I always make sure to use my PSI gauge first. Good Luck.
Donāt some gauges have a little set screw inside where you can calibrate it?
That gauge did in that video that @dperez posted of the guy restoring the inflator gauge. I guess they probably donāt make em like that anymore.
Mine was $15 @ menards, so no set screw thingee. One fella on here had $300 gauges , Iām sure his are rebuildable. @marinegrunt
Just research (setting unloader). Its posted like 6 million times in the archives.
I thought even the cheap ones had it but Iām not sure. You have to split the case open though and itās on the inside. Like you said the cheap ones might not have them.
Dunno, Iām just guessing. Iām not good with lil parts and due dads man. You outta see me inside a DS injector with the spring and ball. Not pretty, not at all. @marinegrunt
I donāt think my vickers gauges are rebuildable. Never had any issues with them but I only break those boys out when Iām setting hydraulic pressures on tractor hand pumps for autopilot. Usually if my Cheaper ones act up I trash them and charge back to the company for replacement.
So Your the high dollar gauge fella. Good advice, thank ya @Redwal9451
I used to run 50 ton excavators, D11 dozers etc, etc⦠I was Always fascinated with the mechanics and there high dollar gadgets and gizmos.
My opinion if I was to put one on the end of my hose it would be the cheap $20 ones. Eventually your going to drop it or hit it on something might as well get a couple and have a spare. I would keep a descent one at the pump to monitor every so often. But thatās me.
What kind of wood is it?
