Quick question - I apply chems with the black tip for low and a shooter for high. I’ve never been happy with the delivery of the black tip and wondered if the Jrod was any better? (for low soap application).
(Using a 4GPM and I’d just make the single low nozzle if the answer is yes)
The “J-Rod” is the common name for a device that holds typically 3-4 nozzles. The “j-rod” itself is not a spray tip of any sort. You can put any tip you want in a “j-rod” to get all different spray patterns.
To answer your question, yes there are better soap nozzles out there than the black tip that comes with machine. Go pick some out and screw them into your “j-rod”
You can buy the Jrod with all 4 nozzles for your specific gpm machine at pressure tek pretty cheaply. A whole lot of people use them and love them and even get sweaters for them (thats a separate topic). But try it out for a bit and then try the black tip and compare.
I’m happy with the shooter, just not the low black nozzle.
I don’t want the Jrod itself, as I have the female quick connects etc. So, if I order a nozzle, which one would be ideal for low housewash and driveway application?
I’m familiar with them, 100% but sellers are hard to come by here in Australia. I figured I only have a problem with the low pressure black tip, so I’d buy a single nozzle and go that way
I know it’s not exactly what you asked but I really like a m5ds nozzle. It can shoot high and with a twist it fans out. It’s not the best high reach tip but so far it does everything I need.
I agree the m5ds tip is what I use 99% of the time. It’s very versatile because you can adjust from a 8ft fan to high soap tip with just a twist. I appreciate that you can adjust to a 5-10 degree fan so you can hit the gutter and soffit in one pass. The jrod tips are limited to 2 spray patterns.
Soap concentration stays the same with m5ds. The high pressure tips I rarely use on a j-rod. I’ll use the fan rinse tip for decks, brick stoops, and edging driveway. The high rinse tip I’ll bust out if I need to knock down hornets nest residue or something on a gutter that needs more pressure…but that’s rare.
That’s right, I have used it with my 12v system and also as a down stream and just a high volume low pressure rinse, I prefer it when house washing vs pressure tips.
