Best place to buy a new Washer?
mine almost looks like that with a ladder rack on top. I built mine on a jet ski trailer add a base with the ladder rack 50 gallon buffer tank and 26 gallon chemical tank 3 reels hose 200ft of pressure, 150 of water feed and 200 ft of low pressure. 670 HF with gear driven 6 gpm pump pressure pump (plans to move up from here in gph) and 7 gpm 12v pump. I do have remote cut off for soap on the injector which does save a lot of time. Working on a injector bypass system.
What’s in the large storage box?
3 Suttner guns, 3 lances, a few J rods, adjustable wrenches, channel locks, screwdrivers, socket set, O rings, spare DS injectors, voltage detector, frog tape, spare pump, box of trash bags, jug of citric acid, dental pick set, can of WD40… about to add a battery box in there & run cables through the side for electric start.
Ok sooo after reading all of that. I am trying to figure out the best set up to start. Lol. This is what I got Soo far. It sounds like the gx 390 with a comet pump that says 3000psi and 5.5 gpm really isn’t what it claims to be at least for flatwork with a surface cleaner? Appears that maybe the 630 or 690 with 8gpm may be the way to go? I am a little concerned that racer comments that there are places that are staying wrong specs? How can I distinguish that?
The basics as I understand it?.. don’t buy from the places listed as giving bad info, that’s just bad business… don’t worry about specs other than gpm, buy tips and adjust accordingly.
