Best concrete cleaner down stream injected?
Please shoot me what y’all use to clean up like hotel parking lot concrete and also residential drive way concrete…thanks in advance for the help!!!
Id sure like to know the answer to that question too.
Ive bought name brand concrete cleaner concentrate and used it, however i wouldnt say it brightens it any…Its more of a degreaser.
SH and dawn (or laundry soap) is the most common ive heard of…
Oxalic acid, or Aluminum brightner for stain removal??
Anyone , anyone?
Yeah, I ran Oxalic acid on a rust spot that wouldn’t come clean. Its possibly from a golf cart battery however. Im still looking for the best chemicals for stained concrete. My house wash does the minimum but no luck on the bad spots.
On Residential, a regular house wash mix downstreamed will do the trick. Just give it a little dwell time and you are good to go. Commcerical depends on whats on the concrete. Degreaser ( EBC ) if nasty dumpster pads or if its just sidewalks–clean and post treat with HW mix.
Any particular brands you recommend? Is there a brand/chemical that is best to use on both the house and concrete? Trying to keep it simple. I’ll be doing mainly residential…driveway, house. Thanks!
sodium hypochlorite, I.e. SH or “pool chlorine”.
welcome back
thanks man :call_me_hand:
Thank you!
