You can’t expect to come here, give bad advice and not get called out on it lol. P
I see your pipe down and parry with
Theres nothing wrong with giving a customer a deal for bundling services. It would be foolish not to. We offer a couple different bundle options when we give a quote trying to get that high ticket. You don’t and that’s fine for you but let’s not be rude and insult others or you’ll get it back
I agree, nothing wrong with giving a discount for building services. I don’t think you read his post though.
Unless it got deleted? I don’t see anything I disagree with.
How do you clean a stucco home safely in that situation?
Rinse the windows ASAP or at the same time you’re applying chems.
Yes. Another thing I started doing sometimes (that I’m pretty sure it helps but sometimes it’s hard to tell) is after one side of the house is washed and rinsed (including the windows, window tracks and frames, and all that stuff) is before the water dries from the final rinse, hit it with the DI water and waterfed pole. That way the tap or well water does not dry on the windows, leaving water spots that is harder to get off. Brock, would you agree that this makes sense? or do you think I’m trippin?
