Searched the forum here and the only mention of Fat Daddy is the username Fatdaddy. Searched EnviroSpec as well and didn’t get much information except it seems that @Innocentbystander is not a fan but @Racer has used their hoses and some of their soaps.
If you don’t mind sharing. What is your current softwash setup? 12V, X-Jet, dedicated gas powered system?
And do you see a benefit of using the foam over a non-foaming application? Is it the “wow” factor that puts it over the edge for other potential customers as they walk/drive by? I believe I read that the foam tends to cling better, but that is usually from people that use the foaming technique over non-foamers.
I hope you didn’t summon the Chunky Father here by tagging him… dude said some really dark stuff about his wife and women in general right before he left so his presence isn’t really missed…
Is it too late to untag him in your post? Can you try?
That pump looks to be Allison’s version of the hydpro D30, which is an awesome pump, I’m very familiar with the D30. The only issue I see is that it has a bypass regulator, which means it circulates constantly back to you tank, which would foam up like CRAZY in this application. Back in my lawn care days (20 yrs ago) we used a de-foamer agent to keep the foam from overflowing out of the tank!
I’ve thought long and hard about a soft wash system with a D30, but haven’t been able to find a way around that issue. You can get a Honda gx160 and a D30 combo for around $1000
I’ll look into the alcohol thing. I think a D30 pump and a JD9 spray gun would be the perfect setup.
The adjustable tip is amazing for height and control. I used this setup to spray trees back in the day, and never had any issues.
