[MENTION=7598]ksroofs[/MENTION] what are you pulling it with?
I pull it with a ford ranger with the 4.0 . Keep in mind I donāt ever have water in it, at most just chems.
I did a house the other day with my dual axle trailer. I try to shut the water off early enough so that it is close to empty when I hit the road but forgot to do it. I ended up driving home with about 150 gallons in the tank, you definately can feel the sloshing around and how it pushes causing a jerking motion on the trailer and truck. I also have brakes on the trailer. It definately is a strange feeling toting water around for someone that may not be used to it such as myself.
I believe I saw your video Lee, did you get the fatboy in there? Iām debating on closed or open they both have pros and cons. I think without a big garage to store an open trailer the closed would be ideal.
Josh Rouse
Carolina Clean
716-680-1326
josh2726@gmail.com
Here is the link Powerwashing Trailer
I havenāt put the fatboy in yet, its at our shop still and its been snowing the last day and a half⦠Last year we ran the all-flow pump with the rigid compressor but found it to be a bit more of a hassle
You can avoid the water surge and almost stop that jerking motion by using these⦠http://www.surgecontrolsystems.com
A little pricey but they do the trick! I try not to haul water but when I forget to turn it off in time, these make the trip to the next job a little more enjoyable.
Don
Fresh Look Pressure Washing
Good idea Don
I think [MENTION=6909]Russ Johnson[/MENTION] carries a water slosh blues solution also.
This is what I carry⦠Surge Buster® drop-in baffles for any size liquid tank. - Liquid Surge Control, LLC They are $23.00 each, and you need 1 for every 30 gallons of tank capacity.
You would think they would just build the tanks with grids built in to create multiple chambers. This would work much betterā¦
I think iāve seen one before but I cant find it right nowā¦
I know itās corny but Iāve always looked at it like this.
Build it slow and watch it grow⦠Build to fast and you may not last.
That makes sense. I may just pay cash for a second 4gpm and see where it takes me.
Sent from my Nexus 5 using Pressure Washing Resource mobile app
We just have a valve to dump extra water on trailers. 2 inch line drops 200 gals quick.
Sent from my iPad using Pressure Washing Resource mobile app
Are you able to dilute your SH with that size injector?
Alex has been gone for awhile. Injectors donāt dilute anything. They do pull at different ratios though.
Nice rig.
Is the gas tank on the same side as your vehicle?
Very clean, and not over the top⦠
Where did he go?
No but I wish it was
