Unloader not set right, oversized pump, wrong injector…no wonder it’s acting wonky!
Now you mentioned a bypass, was that added after that first pic was taken? Also that whip line is pretty darn long.
That size injector was recommended by pressuretek. Didn’t know.
Yes it was
Gotcha.
Yeah put a 2-3gpm injector on there and it should pull like a freight train,
And if it doesn’t ?
Yes, you definitely don’t want the 5-8 gpm injector. Most with a 5.5 go with the 1-3 gpm injector.
Whether you are doing PWing for a living or side hustle you’re going to need to be able to troubleshoot your rig. This is part of your education.
That’s a massive amount of unnecessary restriction. 2-3 or 2-4 gpm injector is perfect for a 5.5 machine with 200+ feet of hose.
I understand. Just very frustrating.
Then we’ll troubleshoot some more. It’s just way it goes sometimes. It’s good to have these things happen. Next time you’ll know exactly what the issue is.
And you’ve taken the filter off your soap line right? As an emergency you can certainly use an X-jet but for everyday use you definitely want to DS.
Yes I have
I understand… any other site besides pressuretek to order a 2-3 injector?
Tons. Where are you located? There might be a store nearby.
Western New York
Near Buffalo or ?
Yes sir
These might have them in stock. Remember you want a DS injector for 3gpm or less.
Had a feeling you might say them. About an hour away and closed till Monday. I’m thinking if I order one online rn it’ll be here Monday.
I’ve got 4 PWing suppliers in my metro area but only the Landa dealer has a decent inventory and he’s not cheap.
