X-Jet Method For Green Mildew House Wash Options solution Options
I use an X-Jet on a 4k psi / 4 gpm direct drive to clean the green and such from homes here in Northerly GA. I used to rent but now have a new rig in shipment.
I have only known one kind of house wash but its getting kind of pricy and want to hear what some of you guys use, rather it be your own mix or a purchased one. I want to refrain from mentioning the mix I use and see what comes up here and keep bias out of it.
Thanks
Well if your mix is expensive it probably won’t be mentioned here and lose the xjet and start researching down streaming you’ll feel like your coming out of the stone ages. I’ll let someone else give you the down low on mix.
Okay, come clean Gapi. What is your mix?
My mix costs me about $5.00 per house. $4.00 worth of bleach, about $.90 worth of eLemonator and two nickels worth of water.
eLemonator. Get ya some.
x-jet thing. I own it. I have used it once in six years.
ELEMONATOR IS A LIQUID HOUSE WASH AND MULTIPURPOSE CLEANER THAT NOT ONLY IS BLEACH STABLE BUT ALSO BOOSTS THE ALKALINITY OF BLEACH. IT HAS GREAT FOAMING AND RINSING PROPERTIES AND THE STRONG LEMON SCENT DOES A GREAT JOB OF MASKING THE SMELL OF BLEACH
Yes, I am in the stone ages I admit.
Old habits are hard to break and the time and expense in experimenting with the new has me balking. I am pretty proficient with my prehistoric setup. No-doubt things would be better but I’ll have to experiment in the off season. My head has been in the sand.
My X-Jet is an M5 Variable, I have a lightweight hose going to it with a little petcock type shut off and a little anti-drain back check-ball in the line withing easy reach.
I really like how I can reach the chimneys on two story homes. I can see down streaming in my future.
My mix is Sunbrite’s Supply Power Wash. I have to have it shipped 5 gallons at a time. I can’t get it off my mind there has to be some way to go easier on my over head.
Any suggestions would be great.
Sorry, “Power House” is the name. Why is there no edit option here, heh!
The choice is your. Sunbrite has some good stuff, probably.
Adapt or die.
Natures law. Not mine.
I guess I am a glutton for punishment. I keep coming here asking for info and keep getting other than I asked for. Lots of perky little witty statements but nothing on the subject matter I asked for.
Once bitten twice shy. I asked about chemicals and get hammered for my equipment.
You will not get another opportunity.
My apologies Sir.
Please re-read your original question. Peruse my response and then clue me in as to what I am missing.
You asked about a mysterious over priced yet anonymous detergent.
I specified a very cost-effective solution.
And now you are shy?
What is it that you are seeking Gapi Guy?
looks like a quality answer to me
Josh Rouse
Carolina Clean
716-680-1326
josh2726@gmail.com
No reason to take it personally- I doubt anyone here thinks less of you because you are comfortable with your current setup. I’ve yet to get into the powerwashing game myself, and when I do, it will most likely be with rented equipment and a less than optimal setup. But the guys on here have been super helpful, and not in the least demeaning about my humble beginnings.
The thing to remember about people on industry forums, is that most of them are serious business owners, and are here seeking ways to improve their methods, as well as give a helping hand to others. So when we read from someone who doesn’t appear to be as serious, there’s a tendency to try and ‘enlighten’ them to a better way of doing things. Taken in this context, I think its easier to take people’s responses less personally.
If it was more options you were looking for, just check pressuretek.com or one of the other suppliers mentioned here. Read up and see which one(s) you’d like to try. But eLominator sounds like a great choice, and probably what I’ll be ordering soon.
try the search feature… This topic has been covered numerous times before… its how I learned!
But for me - SH, Freshwash or simple cherry, and some good old dihydrogen monoxide.
also dump the x-jet… downstreaming is just so much easier…
