I’m trying 25025 X4 on my WW to help bring the pressure down some. May go to 2503 later
I did search but still don’t see it. I know the bar is soft is it better to use lock tight or tape
8GPM
The general consensus around here is Teflon tape for high pressure fittings. Tighten spray bar tips just until snug while being in line with the bar. Definitely don’t want to strip those threads. I’ve seen a few suppliers recommend blue thread lock for fittings but I don’t like the idea.
Thread lock is great until you get some trash stuck in the nozzles and have to break the nozzle free. Teflon tape works well.
Good point.
